Spark Plugs for 2003 S7
on
RE: Spark Plugs for 2003 S7
You are using one of the three or four best plugs on the market, doesn't make any difference the year or mileage on your truck.
What will make a difference is at your mileage, if you haven't replaced your plug wires, they are holding you back.
You would be wise to install a set of 8 mm Magnacor plug wires to enchance the voltage for your plugs.
Thanks a lot, Mike.
Other than Magnacor, do you have any other brand to recommend? I have a set of STI wires from Karlyn Industry. Don't know if they are good or not on a Land Rover? Thanks!
just so you know that I am working on the wires, it's just so hard to get the access to the coil end...
Everybody recommends the Magnacor wires because they know that they will work on a LR. Some wires just will not hold up, some have put new wires on and had to replace them again less than a month later.
As for spark plugs, each to their own, I use Denso Iridium plugs in my DI.
marsyas
02-25-2021 08:11 AM
