Spark Spug Gertting Dirty very fast!
Hi, I have a 99 Land Rover Discovery and the spark plugs are getting so dirty that eventually it won’t start. When I take them out they seem burn like if they were passing to much gas, or something. I have to clean them like every week so that it could run smooth. If anyone knows how to fix it,please let me know. Thanks
on
RE: Spark Spug Gertting Dirty very fast!
The color of the spark plug will tell you what is causing it to get so dirty. Normal color should be a tanish color. Here's a link to help you out. Once you determine your color, we can begin to further diagnos the problem. http://www.spark-plugs.co.uk/pages/technical/diagnosis.htm
Well I just put a New engine of 67 miles, I believe. The old engine has 149 miles. About the plugs they are champion and I believe the wire are leoni.About the gassometimes I switch from regular unleaded to the middle one. According to the chartof the web above,the spark plugs look like they are to rich in air/fuel. Also the they smells like burn gasoline. What could be the cause of that?
