Spark test on #8
So, I have an annoying misfire on #8. It started as an occasional slight miss during acceleration, and now it results in major roughness and flashing SES. There is no coolant loss, overheating or tail smoke.
I hooked up an inline spark light this morning and let it idle for a couple mins. No codes and light seemed to flash ok. Revved it a few times at 1500-2000rpm for about 5 sec each. No lights and it had a minor vibration, but nothing too bad. Tried to go for a short drive, but the stumbling and flashing SES started right away so I went back and parked it.
A few hours later, I put some Redline SL-1 in just to see if it might be injector related and went for a drive. Did fine until I got to temp (190ish). Started flashing the SES and running really rough. Used some welding gloves to hook the test light up and took a vid.
Is this a normal fire frequency?
Note: dark garage so it looks like a blank screen. Watch for the little orange flash in the middle.
It has been suggested I do a compression test.
Online opinions say that the Craftsman tester is a good unit and as cheap as one should go. At $65 it isnt too bad a hit, but I would rather avoid buying something that may get used a handful of times tops.
Does anyone have opinions on the quality of a loner unit from the auto parts stores?
Ok for a start, but a leak down test will give you better/more accurate information and if you have low compression you'll want to do one anyway to know what's causing the low compression.
Have you verified your plug, wire and coil pack are good?
Did you check out the first video I posted of the spark light?
If you have to a leak down tester I'd just do a compression test using a tester from the auto parts store rental. If it looks good then don't worry about the leak-down.
If you have bad compression in one or more then do a leak-down to verify what's leaking.
