Speaker noise in 03 Disc SE7
I just bought a 03 SE7 without the the Harmon Kardon system. The left, front speakers in the door, make noise. It sounds like a buzzing (verrry noticable), and is independent of the volume control or any of the radio buttons. As long as the radio is on te sound is there.
I swapped out speakers from the other side, its not the speakers.
I checked the wiring in the door and it looks to be ok.
How should i proceed? amp?
thanks!
thanks!
RE: Speaker noise in 03 Disc SE7
MA is too far for me.
Well since it most likely is not the speaker assuming there is no modification towards the existing wiring I would assume it either be the amp or the headunit. The best way to test the amp is take a look at the wire color combo on the side in question where it originally hooks up to the speaker with the buzzing sound. then look at the other side and just simply swap the wires around. If the buzzing sound is shifted towards the other side then you know it is not the wiring. Oh make sure all of your connections are not loose. In my professional opinion I would have to say there is something wrong with the amp or the built in crossover. If you are not too savy with electronics just pick up an amp on ebay and replace it (if you can find one). Or you can swap out the amp for an aftermarket unit.
euronavdiscs
02-06-2016 03:41 PM
VikingDiesel
10-25-2009 09:33 PM
