cracking/scratching like noise coming from rear speaker... sub??
Old Oct 23, 2009 | 09:53 PM
VikingDiesel's Avatar
Default cracking/scratching like noise coming from rear speaker... sub??
Not all the time but more like when I first start the car or drive around, ill get a scracthing like noise from the rear speaker, its coming from the drivers side left in the trunk right along the glass. Sounds like a loose connection as if you were scratching a live wire against something, im not getting much bass at all, isnt that where the rear sub is located and if so, are all the subs from 95-02 the same?
Old Oct 25, 2009 | 02:53 AM
neverming, my bass speakers in the back are blown, anyway I can just buy some aftermarket ones and make it work since the aftermarket ones will most likely not have the the whole for the screw for the amp?
Old Oct 25, 2009 | 12:34 PM
handsome rob's Avatar
I have not done it on my Range but on my Disco I replaced the dual subs in the back and just mounted the amp inside the enclosure and not on the speaker itself. That may be a way to get it going agan without having to go OEM.
Old Oct 25, 2009 | 09:23 PM
what did you replace it with? just regular speakers from best buy or somthing? Also, what size are those speakers 6.5"?
Old Oct 25, 2009 | 09:33 PM
On the Disco they are 6.5", I had to go to a specialty shop to get the speakers though. If you can find just a sub at Best Buy in the right size then it should work just fine.
aftermath431
Audio/Visual Electronics
Sep 10, 2014 09:36 PM
yobob
Apr 4, 2013 11:42 PM
georgep
Aug 15, 2012 04:33 PM
seamuspg
May 11, 2009 07:39 AM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
