Speaker wiring gurus
Old 02-18-2019, 08:54 PM
Ben Matheson's Avatar
Default Speaker wiring gurus
Got a pair of 6.5 subs to replace the lower speakers in the passenger doors. After taking them out of the box they appear to be dual voice coil with 2 sets of leads/ connections. How the heck do I wire these? Want to be careful since I think these are already wired in series with the truck door woofers
Old 02-18-2019, 11:56 PM
Icannap1's Avatar
The box that the woofers came in should specify how many ohms are each voice coil then ohms law is used to get it to a 4 ohm load if it is the factory amp but if you are wiring a aftermarket amplifier then see what are is the minimum load the amp can take. Most high end aftermarket amps ex. Alpine, Rockford Fosgate, Kicker can handle a 1/2 ohm load but 4 ohms is the standard for car stereo.
Example using 1- 4 ohm dual voice coil woofer in series will give you a 8 ohm load, that can be done by connecting the negitive (-) terminal from your amplifier to the negitive (-) speaker terminal of the first coil, then your positive (+) terminal of the same coil will be tied to the negative (-) terminal of the second coil, and last your remaining positive (+) terminal will be the other lead going to your amplifier (+) speaker terminal.
Now using 2- dual voice coil woofers set up for 8 ohm can now be wired to each other in parallel will give you a 4 ohm load, to do this you will first need to wire the 2 woofers identical as stated above then connect the negitive (-) speaker terminal of the first coil to the other woofers negitive (-) speaker terminal of the first coil (parallel), do the same for the positive (+) speaker terminal of the second coil to the other woofers positive (+) speaker terminal of the second coil (parallel), now you have 2- 8 ohm speakers in parallel then in series that now gives you a 4 ohm load.
Image above shows 2 ohm voice coil woofers in series parallel. 2- 4 ohm loads = 2 ohms
Using 4 ohm voice coil woofers in series parallel. 2- 8 ohm loads = 4 ohms.
Use same wiring diagram showed above just use appropriate voice coil resistance that your amp can handle.
Old 02-19-2019, 06:57 AM
Wow thanks. So as far as a drop in replacement I kinda blew it. Planned to run these with stock amp and head unit.
Old 02-19-2019, 12:02 PM
So can anyone chime in on running this in the 2ohm configuration with the stock amp?
Old 02-19-2019, 03:26 PM
NewToTheTwo's Avatar
Post
You'll blow it up for sure.
The odds of a stock amp being able to run at 2 ohm is slim to none and not worth the risk IMO.
Run the voice coils in series for 8 ohm and never worry..........
General speaking I think stock sound systems are designed for efficiency so its probably designed for 8 ohms already.
This thread might help - https://landroverforums.com/forum/di...mplifier-7662/
Old 02-19-2019, 06:44 PM
Icannap1's Avatar
If you buy 2 single 8 ohm voice coil woofers you can wire them in parallel that will give you 4 ohms. The factory amp can only handle 4 ohms minimum or you will fry the factory amp and if you buy 2 single 4 ohm voice coil woofers and put it in series you will have 8 ohms the problem with that is you will get less output from the factory amp best to keep it at 4 ohms. Car stereo usually 4 ohms, good car audio amps can do 2 ohms, expensive car audio amps can do 1/2 ohms, and all house audio systems run 8 ohms as where Bose runs 6 ohms. Don't complicate it keep it at 4 ohms - Good luck.
Old 02-19-2019, 06:51 PM
The link I provided above says different.
Stock system is 8 ohm
Old 02-19-2019, 07:00 PM
XRAD's Avatar
I measured the resistance of each Philips OEM sub, 2 ohms each speaker. They are wired separately back to the amp. Not sure if there is a difference in audio amplifiers based on model.
Old 02-19-2019, 07:48 PM
Twix's Avatar
Rear door subs are different than the door mids. They should be 4 ohm. You could get a resistor and put it in series with the speaker to make it effectively 4 ohms. If your speakers are 2, get a 2 ohm resistor.
Old 02-19-2019, 11:46 PM
Icannap1's Avatar
That is good so all that needs to be done is to wire them in series it will be a 4 ohm load at that point so no resistor is needed.
Discosomewhat
Audio/Visual Electronics
05-30-2021 09:35 AM
robersonb
10-28-2018 07:12 PM
aroshan
07-04-2017 07:27 AM
stephenaustralia
04-17-2013 12:12 PM
JEFIII
04-23-2008 11:10 AM
Quick Reply: Speaker wiring gurus
