Speedo sensor?
Speedo sensor?
My speedometer started fluctuating then going to 0 then fluctuating again and now it doesn't work at all. I have a real time scanner going and the computer is reading 0.0 miles per hour. Should I assume it is the sensor and not corrosion on the computer? Where is the sensor located on the transmission and what is the process to fix it?
Thanks a bunch!
Thanks a bunch!
Received 1,189 Likes
on
Also, check continuity of speed sensor wire between trans module and connection on transmission...especially if the vehicle has been sitting for a while. Had an issue with my wife's 03 after replacing engine (vehicle sat for three months, while looking for an engine). During the wait, a mouse decided this was a good time to chew through some transmission wires inside the center console. I pulled the window switch panel and looked inside console...lowandbehold...chewed up wiring harness.
Brian.
Brian.
