Spring Retainers needed.... maybe??
Old 02-21-2017 | 03:44 PM
80's old school's Avatar
Default Spring Retainers needed.... maybe??
I installed the Terrafirma 2" spring and shock package a few weeks back.
This weekend I went "wheeling" and got into some trails that incurred "wheels lifted" situations.
I heard same clanking noises. I am quite certain it was the coil springs un-seating and then seating back in.
Do I need spring retainers with the TF 2" kit?
If I need them, can they be installed without removing shocks and springs on the front and springs on the back?
That would suck to pop out a spring...
Old 02-21-2017 | 03:54 PM
fishEH's Avatar
Retainers or cones. Pick your poison. If you go retainers make sure they are heavy duty. I've bent way too many thin gauge steel retainers. The stock ones suck. they get folded into a U shape.
These work very well.
https://www.ballisticfabrication.com...pring-retainer
Old 02-21-2017 | 04:30 PM
Jeff Blake's Avatar
It sure does seem like springs could pop out pretty easy without them, especially with sways disconnected. I went with the TF retainers.
Pretty painless to install, you can unbolt the shock at the bottom, pull the shock up an inch or so, insert through the spring retainer, bolt down. Need to be lifted in the the air by the frame of course
Old 02-21-2017 | 05:34 PM
What if I don't disconnect sway bar... is there a chance of springs "parting company" if the sway bar is intact?
Old 02-21-2017 | 09:58 PM
Twix's Avatar
Yes. The rears for sure, the fronts might need a little more articulation to unseat.
Old 02-22-2017 | 01:09 PM
Sounds good. I will look into adding them to the rear. I looked under there yesterday and it does look like the spring could easily pop out if pushed too hard.
Jeff Blake
02-17-2017 09:01 PM
Paul Grant
07-30-2016 10:01 AM
peanuts8888
12-26-2012 05:53 PM
sclarkie
09-07-2011 07:04 PM
Timpala`
02-02-2010 06:44 PM
