Spring Spacers
Old 01-23-2013, 11:25 PM
ZGPhoto's Avatar
Default Spring Spacers
Does anyone know where to find custom height coil spring spacers? I've got the Terrafirma "3" inch lift and am netting 1-1.5" of lift, I'm looking to get some 1.5" coil spring spacers to bring the height up a bit.
Thanks,
Zack
Old 01-24-2013, 12:08 AM
binvanna's Avatar
Lucky 8 and Toddco come to mind
Old 01-24-2013, 12:54 AM
ZGPhoto's Avatar
I checked, couldn't find anything. I saw 1" and 2", and a .5" but I'm not trying to stack spacers.
Old 01-24-2013, 07:44 AM
jeffh's Avatar
try these guys, I am sure that they would be willing to make you whatever size you wanted.
Welcome to RTE Welding & Fabrication!
Old 01-24-2013, 07:55 AM
ZGPhoto's Avatar
Emailed, thanks Jeff.
Old 01-24-2013, 08:10 AM
something is wrong here. i got 2 1/4" with the 2" TF HD springs.
Old 01-24-2013, 08:15 AM
ZGPhoto's Avatar
On your DII or RRC? I'm at around 20.5" and 20" from center of the wheel cap to the bottom of the wheel arch.
Old 01-25-2013, 06:33 PM
binvanna's Avatar
Thanks,
Zack
Have you put your vehicle on a truck scale?
Old 01-25-2013, 06:38 PM
ZGPhoto's Avatar
Nope, not yet. If you check my "measurements" thread I'm at 20.5 and 21" rear. So 2" lift in the rear and a little under 1" in the front.
RTE(Rovertym) is making me 1.25" spacers for the rear, and 1.75" for the front.
Old 01-25-2013, 06:51 PM
aarongregor's Avatar
Zack (ZG) I will post pics on your other thread tomorrow but I have almost the same set up as you minus the roof rack and I am 22 in the rear and 22.5 in the front. I added a 1" spacer to the front with my TF 3" lift. I will be adding a winch so im guessing that will level it at 22" all around. Here is a link to a 1.5" kit Lucky8llc.com - ToddCo Products for Land Rovers
Quick Reply: Spring Spacers
