Spun Rod Bearing Replacement
Old Mar 19, 2008 | 09:59 PM
zracin's Avatar
Default Spun Rod Bearing Replacement
How much should I expect to pay to replace a spun bearing. I have a mechanic i know and trust, that will show me every step of how to do everything myself the next time. Real good guy. My second question is; should I take it to a land rover specialist or this guy? or does it not really matter for something this simple/universal?
Old Mar 20, 2008 | 08:04 AM
Landzu's Avatar
Default RE: Spun Rod Bearing Replacement
What are you going to do rebuild the motor or just replace
one bearing?
A motor replacement runs $7000 to $8000 USD.
A rodbearing means that the crank needs to be turned and the rest of the bearings are not far from the same thing.
If you just trying to fix it to sell it you may need to replace
all the bearings,, that I would let your mechanic do he sounds like he can do it.
With the fact that he will tell you how to do it I'm sure he
will be fair on the price.
Old Mar 20, 2008 | 08:28 AM
antichrist's Avatar
ORIGINAL: Landzu
A main bearing means that the crank needs to be turned and the rest of the bearings are not far from the same thing.
He says it's a rod bearing.
ORIGINAL: zracin
No idea, never replaced just one bearing. I assume you and he are going to do it in place, not tearing down the engine, so I wouldn't think it would be that much. Drop the oil pan, remove the conrod nuts, turn the crank, replace the bearing.
Any good mechanic should be able to handle that. I wouldn't worry about taking it to a rover "specialist".
Old Mar 20, 2008 | 11:21 AM
geotrash's Avatar
Doing a rod bearing can be quick or it can be the tip of the iceberg. If the crankshaft rod journal is scored and damaged, then the crank has to come out for machining or replacement. At that point, you're pulling the engine and putting a freshly overhauled one in from roverlandparts or craigslist.
Dave
Old Mar 21, 2008 | 04:59 PM
zracin's Avatar
entertaining ideas of motor swap . Forwhat arover motor costs- wouldnt it be better and close to the same price to swap for a 350 motor/tranny
Old Mar 21, 2008 | 06:30 PM
Landzu's Avatar
You could pick up a low mileage motor from
http://roverlandparts.com/
Old Mar 22, 2008 | 01:29 AM
kraelo's Avatar
I'm assuming it's ur 95 you're talking about, extremely easy to find used engines or parts for under $500 ..... you're a bit of distance away from me so If I found something for you shipping would be $300 or less (ranging from complete motor - crank and parts)
pm me if you're interested ...
i have some good and blown motors, i can tear apart for parts that you would need, if your crank ends up being cut pretty deep (depends on how long you drove it with the spun bearing)
Old Mar 22, 2008 | 12:13 PM
zracin's Avatar
i drove it about 15 miles from the point i could tell something was wrong.
Old Mar 22, 2008 | 12:16 PM
zracin's Avatar
back to my original questions though..how much do you see this costing me (replacement of just one bearing)...a few hundred, a thousand?
Old Mar 22, 2008 | 11:11 PM
geotrash's Avatar
ORIGINAL: zracin
It depends entirely on what you find when you get the oil pan and rod caps off. To have a looksee, I would expect a coupla hundred. If no crank damage, another coupla hundred to put it back together with a new bearing (plus parts). If the crank is shot, you're looking at a complete engine R&R plus the cost of the engine....probably 2K or more.
Dave
