"squeaking under load"
Old 10-28-2014, 09:09 AM
bmeier's Avatar
Default driveshaft
I did drop the front shaft then as i accelerated whilst in reverse in driveway I heard the chirping immediately. There is no chirping whatsoever while in Park idleing at any rpm.. In reverse or drive as soon as i accelerate i get the chirping.
Old 10-28-2014, 09:22 AM
drowssap's Avatar
now drop the rear and go for a ride
Old 10-28-2014, 11:15 AM
bmeier's Avatar
Default Video is finally up!
Old 10-28-2014, 11:23 AM
drowssap's Avatar
THIS VIDEO IS PRIVATE is the message i get when trying to play it
Old 10-28-2014, 11:49 AM
bmeier's Avatar
Video should be good now, Does this noise sound like the rear driveshaft?
Old 10-28-2014, 06:17 PM
bmeier's Avatar
Default squeal
So I just noticed that even while in park at idle if i quickly tap the accelerator to 1500 rpm i hear the chirp, so Im thinking maybe i should look at the belt and pulleys, im going crazy with this one. If only i knew what to fix ahhhh.
Old 10-28-2014, 06:50 PM
Two Rock's Avatar
Take off the belt and repeat the condition that causes the squeak quickly then shut down so you don't overheat the motor, if the noise is gone then you know its probably in the accessories driven by the belt to narrow it down
Old 10-28-2014, 06:57 PM
cappedup's Avatar
I watched a fella drip very small stream of water on a slipping belt to narrow down which bit was squeaking. The water acts as a very temporary lubricant.
Never tried it myself.
edit, sounds more like a pulley to my very untrained ear.
Old 10-29-2014, 04:47 AM
drowssap's Avatar
x2 Take off the belt and repeat the condition that causes the squeak quickly then shut down so you don't overheat the motor,
Old 10-29-2014, 07:21 AM
bmeier's Avatar
Default puleys
wont be able to work on her till later but just in case i need to replace the idlers or tensioner, id rather replace the bearings in them, anyone know what part numbers or where to get em?
Quick Reply: "squeaking under load"
