squeaky sound
Old 12-25-2014, 08:22 AM
dusty1's Avatar
If you have center locking differential capability you can remove the driveshaft and just run the rear.
Or vice a versa
Old 12-25-2014, 09:59 AM
cornbreadj's Avatar
Originally Posted by armyrover
could be 10 miles could be a 1000. What year is your disco?
If that is even the issue.
2003.
Old 12-25-2014, 11:54 AM
Received 1,513 Likes on 1,240 Posts
Originally Posted by Andy2Rover
Could be a squeaky timing belt or tensioner/pulley
Discovery II has a timing chain.
With a 03 pulling the shaft and seeing if the noise is gone is out unless you installed a CDL transfer case. Unfortunately I don't have any spare DII shafts laying around.
When are you heading back home?
Old 12-25-2014, 02:47 PM
cornbreadj's Avatar
[QUOTE=ArmyRover;496605]Discovery II has a timing chain.
When are you heading back home?[/
QUOTE]
We are heading home Sunday evening. We will be in lemont tomorrow afternoon till Sunday
Old 12-26-2014, 08:45 AM
Andy2Rover's Avatar
My bad......I meant to say Serpentine Belt
Old 12-26-2014, 08:55 AM
cornbreadj's Avatar
It only makes it when driving not at ideal or stopped. Its in drive train or brakes
Old 12-26-2014, 09:22 AM
dusty1's Avatar
driveshaft
cv joint
hub
sticky caliper
are possibilities. the first could make for a bad trip. the other 3..... should be to notice if it is coming from one side or the other. cv sound usually changes with turning, but not always. brake noise also usually changes with braking
Old 12-26-2014, 09:34 AM
cornbreadj's Avatar
It starts out like a grinding when driving slow then like a belt sq when you speed up
Old 12-26-2014, 09:49 AM
dusty1's Avatar
if it is a grinding bearing (hub) you should be able to jack up either corner and hand spin test. neutral and spin. then again that much grinding would more than likely give you abs codes for a crazy sensor.
if your centering ball on the driveshaft is making that much noise, i would think a vibration would accompany it.........it doesn't have to, though. same with output bearing.
you really want to rule out the driveshaft possibility first.......that can be tested the same way but with both axles on stands.
Old 12-26-2014, 09:54 AM
cornbreadj's Avatar
I'm about to drive it 40 min to my brother s from my mother inlaws so I can look at it and fix it I hope
Quick Reply: squeaky sound
