Squirting oil
Squirting oil
2004 Disco, was heading home and heard a pop fopllowed by noise that something was hitting the fan. My oil light came on and sure enough I sprung a leak. I just towed it home and haven;t dug into it yet - any ideas of what it may be. I know the gasket around the oil filter but it appears to be coming from around the water pump. HELP
For now, the oil pump is encased in the housing where your water pump mounts to. It's right behind the fan and runs down to and includes your oil filter.
Assuming no damage to your engine, the housing (oil pump gears included) runs about $600 or so new, plus another $50 in gaskets. I think an oil pan gasket is included with that, so you might want to plan on dropping the pan and looking for damage.
The problem with the 4.6L is that Rover outsourced the engines, as I understand it, and the dowl pins are mismachined. It's not a problem with the oil pump, but the machining issues occured on the block. Changing the oil pump by itself might *not* solve your problem in the long run.
disco12
03-07-2006 01:10 AM
