Squirting oil
Old Dec 23, 2009 | 12:09 PM
NORTHERNMAN's Avatar
4th Gear
Default Squirting oil
2004 Disco, was heading home and heard a pop fopllowed by noise that something was hitting the fan. My oil light came on and sure enough I sprung a leak. I just towed it home and haven;t dug into it yet - any ideas of what it may be. I know the gasket around the oil filter but it appears to be coming from around the water pump. HELP
Old Dec 23, 2009 | 01:28 PM
LANDZUII's Avatar
oil sending unit or a oil cooler line
Old Dec 23, 2009 | 03:53 PM
lipadj46's Avatar
There is a bolt in the oil pump area, it may be where you screw in an oil pump gauge. I remember a post where someone found theirs to be loose.
Old Dec 23, 2009 | 05:13 PM
meltdowndave's Avatar
Some '04s also suffer oil pump failures alongside '03s.
I hope that's not the case, though, and it's something simple.
Old Dec 23, 2009 | 09:16 PM
4th Gear
got home and only had time to look around with a flashlight. there is a few small pieces of aluminum in a pool of oil. i have a feeling my oil pump exploded, does anyone have a pic or diagram of th oil pump and its location
Old Dec 23, 2009 | 09:21 PM
You want the RAVE manual, which is available for download. Look for posts by Discomike or Spike. They have the download links in their signatures.
For now, the oil pump is encased in the housing where your water pump mounts to. It's right behind the fan and runs down to and includes your oil filter.
Assuming no damage to your engine, the housing (oil pump gears included) runs about $600 or so new, plus another $50 in gaskets. I think an oil pan gasket is included with that, so you might want to plan on dropping the pan and looking for damage.
The problem with the 4.6L is that Rover outsourced the engines, as I understand it, and the dowl pins are mismachined. It's not a problem with the oil pump, but the machining issues occured on the block. Changing the oil pump by itself might *not* solve your problem in the long run.
Old Dec 27, 2009 | 12:48 AM
Mrmerlin's Avatar
there are a few articles about oil pump failure do a search for "on your own"
Old Dec 29, 2009 | 07:22 PM
4th Gear
Yep, oil pump. It disenegrated and tore through the housing. Everything else looks fine. I will replace the water pump andtiming chain while I am at it.
Memphy03
Aug 3, 2009 08:58 AM
javoli002
Jul 16, 2009 01:24 PM
jkeving
Jan 19, 2008 08:06 PM
shagybruce
Feb 8, 2007 02:52 PM
