SRS airbag fuse blows instantly
I don't know why but the srs light stays on because the SRS fuse blows instantly. Does anyone know where the srs controller or whatever the fuse feeds is located? If I try and pop open the airbag will it deploy?
By the way it's a disco 2 2003
ditto to what mike said get it checked and do not mess with it or u might pay dearly for it.it could be somthing as simple as a seat belt buckle gone bad so dont freak out yet just get it scanned and checked out and get back to us
Ive got a scanner and it doesn't bring up any codes. I am electronically minded, I just found a short in the transmission controller and replaced it now it drives fine but I just need to know physically where the srs unit is located so I don't have to tear apart my wiring harness to trace the wire back to it. I do electrical trouble shooting on controls for commercial airconditioning, so It's not new to me. I just don't know the physical location. If you know it would narrow down the search.
you cant get into the srs system with the scantool that u have most likely the srs has to be checked by a very expensive scan tool.i have a 3000 dollar european scanner and its one of the only ones that can access that so like i said im not trying to be rude but you really should not touch it you have no idea what ur messin with without a code u have nowhere to start diagnosing
I found the srs ecu it is located in the center console under the storage box. I simply unplugged it and pulled it out. You can smell the "electrical burn smell when you open the box and the fuse does not blow when box is unplugged. There was recently an "electrical event" that also blew out the transmission controller. Is it true that the srs ecu is unique to the vehichle vin and can not be simply replaced or that a used one out of a none wrecked disco won't work? thoughts?
dinandan
08-28-2007 04:35 PM
