Srs and self leveling suspension lights on
Old 02-05-2017, 04:19 PM
Luckyjayb's Avatar
Default Srs and self leveling suspension lights on
oo finally got the head gaskets done and all running well but now I have that aggravating bright red srs light on the dash and the yellow or green self leveling suspension on the bottom. There are coils all the way around and it has been programmed for coil springs by the previous owner. Any ideas guys?
jason
Old 02-05-2017, 04:59 PM
BS50MGSXR's Avatar
i guess the self leveling system was not deactivated in the computer. iv not done it to mine yet either and iv had the truck for a year now and iv probably seen the light come on 3 or 4 times.
Old 02-05-2017, 06:25 PM
Luckyjayb's Avatar
it never did it before now but the srs it was has me worried the most
Old 02-05-2017, 08:46 PM
longtallsally's Avatar
I had pretty much every light on the dash come on with mine on the drive home. The SRS came on, but I think it may have been due to cold. Since I had the air suspension programmed out, those lights haven't come on again. The 3 amigos should be sorted with option B getting performed as well as a new wheel speed sensor (I'm lazy and decided to let GBR do it) and the brake light has stayed out as well.
I'd see if you can clear the codes and go from there.
Old 02-05-2017, 09:12 PM
Luckyjayb's Avatar
yea i know. Gotta get the time. My Hawkeye is on backorder now so not happy. I am gonna mess with all the connection under the seat in the morning n see if that might get it
Old 02-06-2017, 01:30 PM
mln01's Avatar
I don't keep track of what each of the diagnostic tools can do but based on your comment it appears the Hawkeye can read SRS codes.
In my case the code pointed to the driver airbag circuit (I don't recall the specific code) so I got another airbag but it didn't solve the problem.
That set me on the path of looking at a short somewhere else in the driver airbag circuit. I learned that overlay harnesses are available so I headed down that path, but before I ordered the overlay I tested continuity all the way back to the SRS DCU that's under the rear of the console and lo and behold I found a short in the DCU connector itself when testing continuity back to the airbag connector by probing the DCU connector from the rear with the wires/pins still in it. When I removed the wires/pins continuity tested as it should. That meant the short was somehow in the connector itself.
Eureka!
That seemed odd to me because the cavities in the connector are designed to isolate each wire and pin, but I nonetheless unplugged the connector and carefully removed the pins, then cleaned the connector cavities with a pipe cleaner wet with rubbing alcohol and reassembled everything.
That solved the problem but I still get the SRS light from time to time. I've picked up another DCU connector in one of my trips to the local boneyards but I haven't yet installed it because removing the console is a pain, but maybe one spring weekend I'll be motivated to do it. I still don't understand how a short can occur in the connector, but oh well.
Old 02-06-2017, 02:17 PM
Luckyjayb's Avatar
Well I got it all sorted out. I unplugged the connectors under the front seats and plugged em back in a few times and it fixed itself.....at least for now I hope
Old 02-06-2017, 08:55 PM
Right on. Free fixes are always the best.
Old 02-21-2017, 05:37 PM
Friday Night Disco's Avatar
So...I was bored today and started taking stuff apart
I noticed that I have the wiring for a self leveling switch but, no self leveling button. Am I to assume that my truck is not equipped with this or that the previous owners did the disable and put a blank there?
FYI - I plan on using this blank for an aux input into my GROM iPhone adapter
Old 02-21-2017, 06:46 PM
Luckyjayb's Avatar
i believe they might have all been wired like that just like the heater windscreen. If you still have the sensors underneath and the air compressor, the previous owner probally swapped em out and just removed it. I unplugged mine since my son loves pressing buttons and I hate seeing that icon pop up know there are coils back there now
Quick Reply: Srs and self leveling suspension lights on
