SRS warning
Old Dec 12, 2007 | 12:31 PM
alanroberts50's Avatar
Default SRS warning
What would cause this to be on? I just put my sterring wheel back together do I need to get the warning light reset?
Old Dec 12, 2007 | 02:16 PM
Default RE: SRS warning
Did it come on before you removed your steering wheel or after?
If after, either you damaged the spiral ring or it has been caused by a low voltage fault caused by disconnecting your battery.
It will not reset itself so ask you mechanic if he has a lap top scanner that can clear it.
Old Dec 13, 2007 | 12:44 AM
Hi Mike, It only came on after I put it all back together. If I had damaged the spiral ring would there be any other symptoms?
Also the red, 2 pin push in connector to the back of the airbag seems quite sloppy/loose, any way to make this tighter without damaging either end of the connections?
Thanks
Alan s1 98
Old Dec 13, 2007 | 08:23 AM
You need to find a mechanic who can read the SRS codes.
Old Dec 13, 2007 | 06:18 PM
Thanks for all the advice, solved. The sloppy connection into the back of the airbag. Every time I carefully lifted the bag off the wheel I could see that the red connector had fallen off each time. Somehow it magically clicked firmly into place on the third try and the SRS went out.
Alan
cipher982
Nov 9, 2019 11:22 AM
ekahi_1
Sep 6, 2012 08:53 PM
jaredkelly411
Mar 1, 2006 10:25 AM
Rovercountry
Dec 25, 2005 09:42 AM
anonimaus
Mar 14, 2005 12:39 AM
