I ordered a set of Goodridge SS brake lines for the 2000 Disco 2, and received part #SLR0109-4P+2, which I understand is the correct part for a Disco 2 with ABS with an extra 2" for lifted trucks.
When I compare them to the OEM lines on the truck, however, they are actually almost 2" SHORTER.
Has anyone run into this? Is there a chance the lines were mis-labelled or mis-packaged? These would be tight even on a truck with zero lift.
