Stall in Idle
Old Jul 3, 2011 | 08:59 AM
Send me your number and I'll call and try and walk you thru your problem.
Old Jul 5, 2011 | 02:34 PM
deucalion's Avatar
7th Gear
787-309-2217 thank you.
Old Jul 12, 2011 | 07:33 PM
deucalion's Avatar
7th Gear
Still dead in the driveway. Tested the electrical connection the circuit has voltage in the relay and fuse on the engine compartment but no current at the plug. Took the pump out and tested it outside just to make sure the pump is not defective and it worked fine. If the CPS is defective will I still get voltage in the relay? If no then there must be another location where the current is interrupted?
willrok13
Mar 7, 2014 08:00 AM
bushpilot
May 22, 2013 12:24 PM
eriqcharlz
Jul 3, 2007 09:30 AM
thesearch35
Feb 19, 2007 10:41 AM
wkujesus2
Apr 19, 2006 12:15 AM
