Stalls, cranks but won't start, P0134, P0171, P0440, P1171, P1174
Old Feb 13, 2014 | 11:26 AM
quadstumbling's Avatar
4th Gear
Default Stalls, cranks but won't start, P0134, P0171, P0440, P1171, P1174
Hi all, first post here. I have a '99 D2 with 142k miles. Last night, my wife was driving it and it stalled out on her. She said it would crank but not catch. After about 20 min of waiting for the tow truck, it turned over and she drove a couple miles down the road and it happened again. Same thing, waited a while and it finally turned over. MIL has been on for a few months (I'm lazy) but I just pulled the following codes:
P0134 - Oxygen Sensor Circuit No Activity Detected Bank 1 Sensor 1
P0171 - Bank 1 System Too Lean
P0440 - Evaporative Emission System
P1171 - Manufacturer Controlled Fuel And Air Metering
P1174 - Manufacturer Controlled Fuel And Air Metering
Your input on where to start would be greatly appreciated!
Old Feb 13, 2014 | 12:14 PM
jafir's Avatar
Check for spark and fuel.
Old Feb 13, 2014 | 12:57 PM
Jared9220's Avatar
98% sure you need a new crankshaft position sensor. About $90 and 2 hours. The sensor is super easy to change but the plug will give you fits. Some people cut out a hole in there fender liner, I got my wife and her tiny hands to help.
Edit.
The other codes may or may not be related to the Crankshaft sensor. I would replace the Sensor, clear the code, and deal with what ever codes come back. If all of those codes return then I would get 2 new front O2 sensors, Smoke check for and vacuum leak, and clean your MAF with a MAF specific cleaner.
Old Feb 13, 2014 | 01:06 PM
Jared9220's Avatar
Here is a link to the part you need: BOSCH Crankshaft Sensor For Your Rover
Here is a link to "How to change your Crankshaft Position Sensor":
Land Rover Discovery Crankshaft Position Sensor (Genuine Part ERR7354) Instructions
Old Feb 13, 2014 | 01:24 PM
4th Gear
Super helpful, guys. Thank you all. Will report back after installing CPS.
Old Feb 13, 2014 | 01:52 PM
willrok13's Avatar
Classic CKPS.
Old Feb 13, 2014 | 07:42 PM
4th Gear
Replaced the CPS, MIL is off, idle is smooth. But $@*%(&@($* was that a pain in the @#(&*$ to clip that thing in!
Thank you all so much!
Old Feb 13, 2014 | 07:49 PM
Jared9220's Avatar
Great News. Another D2 is back on the road!! Now take it off road.
LOL. I told you the sensor was easy, but the plug would give you fits.
How did you end up getting it plugged in?
Old Feb 14, 2014 | 07:53 AM
4th Gear
Through the top of the engine bay, with one hand. If I did it again I would drop the exhaust.
Also, I don't know if this is common knowledge, but I bought the Duralast-branded part at Autozone for $60, and it ended up being the Bosch part in a Duralast box.
Old Feb 14, 2014 | 08:04 AM
Jared9220's Avatar
That is great information!!
Could you make a new thread and Title it "Cheaper Crank Position Sensor" or something to that effect and include a picture, web link, and part number so people can find this info easier when searching.
