Stalls at idle when both hot outside and engine warm
Old Sep 1, 2018 | 07:54 AM
attworth's Avatar
Default Stalls at idle when both hot outside and engine warm
Good morning folks. Recently had an issue crop up, and I’m not sure where to go from here.
While in stop and go style traffic or times like backing out of the driveway (low rpm, low speed), after letting off the gas, the disco will stall. It only does so if the engine is warm and it’s hot outside. Idle drops to less than 500, and then it’s done. Sometimes it’ll stumble back up but normally stalls unless I keep my foot in the throttle a bit. In the morning when it’s below 80, this doesn’t happen, only in the afternoon.
This really only started when I installed clamps on the IACV lines which were missing (2 were missing,) and on the breather tubes going into the valve covers (1 each). Kind of odd right?
Ive replaced the crank position sensor and alternator. The alternator was bad anyway, but replacement didn’t fix the issue. Also got the P38 150A unit. Kudos to whoever posted that info at some point.
I have P0150 active and P0174 and P0505 pending.
Ill be replacing the O2 sensors today, but just wanted to see if anybody else had any ideas of what I should look for. Hoping the IACV isn’t bad as it’s a little pricey.
Old Sep 1, 2018 | 08:23 AM
Best4x4's Avatar
Clean the IAC and make sure when you rotate it in your hand it spins freely inside. Out of my D2’s I’ve yet to replace one. Pretty robust part honestly if you keep it clean.
Old Sep 1, 2018 | 08:35 AM
attworth's Avatar
Gotcha, good to know. Anything specific to clean it with? MAF/sensor type stuff?
Old Sep 1, 2018 | 08:39 AM
04in719's Avatar
Any CEL codes?
I had same issue, would start back up after it cooled off. Was the crank position sensor.
Maybe recheck for tight install and wire connection.
Old Sep 1, 2018 | 05:19 PM
No Doubt's Avatar
If you can keep it running by applying throttle, then I'd suspect the Idle Air Controller instead of the CPS. When the CPS wants to cut out, your throttle won't save it.
Old Sep 1, 2018 | 05:32 PM
Best4x4's Avatar
I use brake cleaner or carb spray on the IAC. And just like No Doubt said if it’s CPS nothing will keep it running.
Loose/dirty MAF connections can cause weird issues, vacuum leaks (check the IAC hose connection to the main intake tube) it can crack and cause leaks at the nipple, I’ve seen plenty of loose upper intake manifold bolts (4 long/2 short bolts) cause vacuum leaks as well.
Old Sep 1, 2018 | 05:39 PM
attworth's Avatar
Thanks Gents. Gonna get cracking on it tonight if my honey-do list ever stops.
Old Sep 1, 2018 | 07:08 PM
attworth's Avatar
Thanks Best. That sucker was pretty stuck. Lots of carb cleaner and some q tips, and she’s idling the way she’s supposed to now.
Of course now my TC and HDC lights are on.
Old Sep 2, 2018 | 10:06 AM
04in719's Avatar
Glad to hear you got the idle issue sorted
Jcodisco2
Jan 20, 2019 07:25 AM
Jennyellen13
LR4
Feb 3, 2018 11:12 AM
cmpeng
Jun 23, 2017 05:47 PM
jacekk
Oct 7, 2013 12:25 PM
Jake1996D1
Jan 16, 2012 05:48 PM
