Started Front Drive Shaft Rebuild
Old Jul 31, 2009 | 10:16 PM
DrCox's Avatar
Default Started Front Drive Shaft Rebuild
hey All,
Just started my front driveshaft rebuild. Pulled it off and noticed it has already been "rebuilt" once before. The front U-Joint has a grease fitting on it but the 2 back ones in the double cardon do not. So anyways...
Finished replacing the front u-joint. I was just wondering, it seems to be really stiff. I know its new but I just want a sanity check that there is no way to screw up the install. I have been following the .PDF that is readilly available here but it does not mention how the newer U-joints feel. I did fully grease it as well and everything seems to be in line.
Also, upon completeion do I need to get my shaft re-balanced? It does not say anything in the procedure as to wether or not this is required.
Thanks,
-Drcox
Old Aug 1, 2009 | 06:45 AM
Your shaft hasn't been built before, the front u-joint always had a grease fitting.
Make sure to remove the plug for the slip shaft, install a grease fitting and lube, then reinstall the plug. Do the same for the rear shaft.
Old Aug 1, 2009 | 08:29 AM
Night Train's Avatar
Mike, I've seen this before and just thought mmmmm - nothing. I'm running a TW now, However I am curious, why can't you leave the grease fitting in the old one? will make that much difference in the balance?
Thanks
Robert
Old Aug 1, 2009 | 04:15 PM
oljohnboy's Avatar
the u joint should definitely move freely. when you reassembled them, did you use a vice? when i did mine, i think too much pressure restricted it a little. you dont want to push them down any farther that where the clip goes. is there any gap between the clip and any of the joints?
Old Aug 1, 2009 | 04:43 PM
CampCobb's Avatar
try tapping it (not the u-joint, just around it) while moving it back and forth. It may loosen it up. I just finished mine today. What a pain in the rear diff. Chin up though, you will have tough times with it but a beer break always helped me. Don't forget to change out the centering ball.
Old Aug 1, 2009 | 08:07 PM
DrCox's Avatar
Thanks guys for the words,
Yeah I have a new centering ball kit...But I have not even gotten that far. I am still working on the 3rd Joint, the rear double cardon. Its a big pain in the but and does not want to push out...But yes beer breaks and relaxing music are proving helpful.
I just want to mkae sure that I dont ruin something with all this time and effort trying to "prevent" A problem.
The Front U joint that I have already re-assembled is right up against both retaining clips. I already pulled it apart once to make sure that there is no needle bearing dropped in there but it went back together just as stiff.
Some of you have mentioned a Vise... Is that easier than a U-Joint removal/installation tool?
-DrCox
Old Aug 2, 2009 | 12:17 AM
oljohnboy's Avatar
we dont have them there tools that actually are for the job you are doing. we use stuff that may also be used to build a deck or redo a roof to work on our rovers!
Old Aug 2, 2009 | 03:10 AM
JBEGIN's Avatar
Mostly i use my structural steel tools, have used my 1/2in. Ratchet Spud for many things
Old Aug 2, 2009 | 09:55 AM
Thanks
Robert
They are prone to being torn off when off wheeling.
Old Aug 2, 2009 | 10:01 AM
DavidG's Avatar
-DrCox
Threadjack.
What size Terra Grapplers are you running? Do you have a lift?
