Starting Issue
Old 08-26-2007, 04:12 PM
chargersfan's Avatar
Default Starting Issue
Just finished the 60k service, but I'm still having a starting issue, I have to push down on the gas to get it to fire. It doesn't happen all the time but enough to be a concern. I did replace the fuel filter also.
Thanks Brian
Old 08-26-2007, 06:34 PM
Default RE: Starting Issue
Did you change your fuel filter, have you checked your fuel pressure, did you clean your throttle body?
Old 08-26-2007, 09:19 PM
I changed the fuel filter, have not checked the pressure or cleaned the throttle body. What do I use to clean the throttle body?
Thanks
Old 08-27-2007, 07:27 AM
Carb spray and if it is real dirty and tooth brush. I would also look at cleaning and or replacing the IAC, idle contol unit.
Old 08-27-2007, 08:03 AM
10-4 Thanks Mike, If you don't mind I would like to give you a call this evening regarding another issue.
Brian
Old 08-27-2007, 09:20 AM
Any time before 8pm Colorado time is fine.
303-862-7680
Old 08-28-2007, 08:18 AM
Got it fixed, cleaned the throttle body and adjusted the throttle cable a little. Starts like a champ now.
Thanks
Brian
Old 08-28-2007, 09:04 AM
Good, most people don't even think about cleaning the t/bosy as a maintance item, it should be done once a year.
Old 08-28-2007, 06:56 PM
willlane's Avatar
Can someone enlighten me on how to clean the throttle body?
Old 08-28-2007, 10:36 PM
Carb spray and a tooth brush, that's what I used as recommended by Disco Mike
Quick Reply: Starting Issue
