Starting Issues
Old Dec 26, 2007 | 12:53 PM
jbremser's Avatar
5th Gear
Default Starting Issues
I have a 95 Discovery (Manual) which has been well maintained and cared for. The maintance is documented from the beginning of its life through now. It has been driving fine and working fine. The car has about 120K miles on it. I came home one night without an issue with it and the next morning it would not start. The battery is good, and it turned over but sounded like is wasn't sparking or maybe a issue with the started. There was a faint steady noise coming from the alternator when after i tried to start it. I disconected the battery for a while and the tried to start it again and still no luck.
Does anyone have any ideas? Am i on the right track with the started and maybe the teeth aren't catching and its a little worn out?
Old Dec 26, 2007 | 01:40 PM
benflynn's Avatar
Default RE: Starting Issues
if it turns over it prob is ot starter related, i would have some one spin it and check if it is getting spark, and if the inj are firing, and if so, then fuel pres
mine (95 disco) floods sometimes, i usally pull the dizzy sig wire and spin it to clear, then it fires up
good luck, mine is killing me
Old Dec 26, 2007 | 01:50 PM
You need to varify if you have fuel pressure at the fuel rail and spark at the plugs, then get back to us.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
stripplerluva
Feb 14, 2008 08:04 AM
jrsherfy
Aug 24, 2007 05:47 PM
clacaria
Mar 18, 2007 03:26 PM
mbroker
Freelander
Nov 24, 2006 10:26 PM
