Starting issues..
Starting issues..
Hey all.. I have a 2002 Discovery II with 150,000 on it.. I am having an issue starting it..
I had the battery checked and it is ok.. I checked the alternator by removing the negative wire when running and it did not die..
I have to jump start it to get it running.. runs fine, but when turned off then I try to start it it clicks as if the battery is dead or it has a bad connection..
I checked the usual connection.. battery terminal and starter connections...
I even put a good battery from my other truck and the same thing happened.. the only time it starts is when It is jumped and even then it gives a slow 1.5 turns then starts to crank faster and starts..
Im thinking it is the starter?? any help would be apreciated.. this is my wife car and we have a 2 week old... I need to get this fixed ASAP!
Thanks in advance..
Thanks in advance..
