Starting issues..
Old Jul 5, 2010 | 06:34 PM
hollis's Avatar
Default Starting issues..
Hey all.. I have a 2002 Discovery II with 150,000 on it.. I am having an issue starting it..
I had the battery checked and it is ok.. I checked the alternator by removing the negative wire when running and it did not die..
I have to jump start it to get it running.. runs fine, but when turned off then I try to start it it clicks as if the battery is dead or it has a bad connection..
I checked the usual connection.. battery terminal and starter connections...
I even put a good battery from my other truck and the same thing happened.. the only time it starts is when It is jumped and even then it gives a slow 1.5 turns then starts to crank faster and starts..
Im thinking it is the starter?? any help would be apreciated.. this is my wife car and we have a 2 week old... I need to get this fixed ASAP!
Thanks in advance..
Old Jul 5, 2010 | 07:11 PM
Yes that sounds like a bad starter to me.
Old Jul 5, 2010 | 07:18 PM
hollis's Avatar
I read another post before that was talking about a oil leak effecting it.. I do have a small leak at the back of my valve gasket.. I tried to smak it with a hammer but still no starting..
how hard is it? I have the rav manuel but want to know the level of dificulty..
thanks!
Old Jul 5, 2010 | 07:23 PM
This is a 30 min job.
The hardest part is breaking the bolts loose.
Not sure about the DII but on a DI they are allen head bolts.
Old Jul 5, 2010 | 07:35 PM
lordmorpheus's Avatar
DIIs are normal bolts, but I don't remember the size as it has been 2 years since I messed with mine.
Old Jul 5, 2010 | 08:24 PM
hollis's Avatar
i checked.. allen..
Old Jul 5, 2010 | 08:39 PM
Doh. I blame large quantities of alcohol involved with my engine replacement for my impaired long term memory. Glad you had the foresight to check before getting heavily into it!
Old Jul 5, 2010 | 10:06 PM
Bundu's Avatar
Banned
9mm allen bolts on the starter, the heat shield has an 8mm bolt if I remember correctly.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
jbremser
Dec 26, 2007 01:50 PM
jrsherfy
Aug 24, 2007 05:47 PM
clacaria
Mar 18, 2007 03:26 PM
mbroker
Freelander
Nov 24, 2006 10:26 PM
