STC53173 mounting hardware
Old Mar 21, 2012 | 08:51 AM
MadScientist's Avatar
5th Gear
Default STC53173 mounting hardware
Anyone know where I can find a mounting hardware kit for one of these brush bars (or at least the brackets)? I bought one recently with an incomplete mounting hardware set and the dealer told me the hardware kit would be $200 (), and that I couldn't buy any of the pieces separately. I have 3 out of the 4 brackets and my fabrication skills are less than impressive, so I'd rather just go OEM if possible (or as close to OEM as I can get). Any nudges in the right direction would be appreciated!
Side note: the one I'm missing is the one that holds up one of the 'wrap-around' portions that goes around one of the headlights, so no I can't just make do without it.
Old Jul 21, 2017 | 08:53 PM
ROB99DISCOSD's Avatar
Previous owner did same thing to mine. Zip tied aftermarket fans. Can't blame em. Stock are expensive. Also looking to fabricate a proper mounting surface. Zip ties make me uncomfortable...
Still debating whether or not to just tank the AC system in it's entirety. Almost made it thru this south Florida summer without AC and it's been hot as a **** so I can live without it. Not a fan of adding load to an old block with 185k. Delete is simple enough. D2 pulley and a different belt.
MiamiC70
Jun 21, 2011 02:07 PM
ghinesley
Nov 19, 2007 02:51 PM
wblake
Oct 19, 2007 08:33 AM
ghinesley
Oct 4, 2007 03:54 PM
wrf
Jul 20, 2006 01:08 AM
