Steel Wheels?
2010 Honda Odyssey steelies have nearly the same specs.
Honda - 5x120 ET 50 7x16 64.1 center bore
vs
Disco - 5x120 ET 57 7x16 70.1 center bore
Both use a 14mm x 1.5 bolt. BMW uses the smaller 12mm, not sure if it matters.
GVWR is nearly identical
Great link to cross refrence wheel stuff - https://www.wheel-size.com/size/land...covery-2/2004/
So you have to have the center bore machined out to 70.1. The wheels are $60 ea. I am going with 235/85/16 so I wanted the skinnier 7" wheel. All rover 16" alloys are 8" that I can find and the factory steelies are silly expensive if you can find a set.
Jacked up to simulate a 2" lift. This is a test fit
vs
Black.Rhino (03-30-2021)
ArmyRover
15
11-30-2017 10:13 PM
toofaroffroad
08-14-2017 05:22 PM
