Steel Wheels?
Old Mar 29, 2021 | 09:05 AM
Art H's Avatar
yes, as somebody has had my rear wheels in saltwater trying to launch or retrieve my sailboat, steel wheels would not survive in good looking shape for long with me.
Old Mar 30, 2021 | 09:10 PM
dswilly's Avatar
2010 Honda Odyssey steelies have nearly the same specs.
Honda - 5x120 ET 50 7x16 64.1 center bore
vs
Disco - 5x120 ET 57 7x16 70.1 center bore
Both use a 14mm x 1.5 bolt. BMW uses the smaller 12mm, not sure if it matters.
GVWR is nearly identical
Great link to cross refrence wheel stuff - https://www.wheel-size.com/size/land...covery-2/2004/
So you have to have the center bore machined out to 70.1. The wheels are $60 ea. I am going with 235/85/16 so I wanted the skinnier 7" wheel. All rover 16" alloys are 8" that I can find and the factory steelies are silly expensive if you can find a set.
Jacked up to simulate a 2" lift. This is a test fit
wjsj69
Jun 20, 2020 07:35 PM
ArmyRover
15
Nov 30, 2017 10:13 PM
toofaroffroad
Aug 14, 2017 05:22 PM
NVDiscovery
Mar 17, 2015 12:57 PM
DirtySE7
Tires
Nov 30, 2008 11:01 AM
