Steering Damper...
Old Nov 11, 2008 | 04:05 PM
sdsilvere38's Avatar
Default Steering Damper...
Do the 96 Disco's have one? I looked underneath the front and did not see one.....
Old Nov 11, 2008 | 04:23 PM
discoxd's Avatar
Default RE: Steering Damper...
my 97 has one... it would be directly behind your front axle... looks like a shock absorber mounted horizontaly..
________
CALIFORNIA MEDICAL MARIJUANA DISPENSARIES
Old Nov 11, 2008 | 04:29 PM
Oh, I thought it was in front of the axle .
Old Nov 11, 2008 | 08:25 PM
Disco2Guy's Avatar
That's on the D2.
Old Nov 11, 2008 | 11:36 PM
mh's Avatar
mh
the D1 has one. It is the horizontal shock absorber behind the front axel. It is easy to replace, if you need to do it. I had a horribles shake over 60, but after I replaced the steering damper the problem went away.
Old Nov 12, 2008 | 12:09 AM
What is the replacement instuctions? Does the truck have to be off the ground? Bilstein good?
Old Nov 12, 2008 | 07:48 AM
ORIGINAL: sdsilvere38
Just take it off and install an OME steering stabilizer, they hold up better and usually cost less the the Bilstein.
Old Nov 12, 2008 | 08:37 AM
discoxd's Avatar
the truck does not have to be off the ground... just lay under there and look... you will see it... and as for removal and replacement, take out the bolts holding it on, take it off, reverse the order and put the new one on... http://www.green-oval.com/joomla/ind...&Itemid=29 .. go to the site and download your applicable file, burn the file onto a cd, and you will have what is called the rave manual... tells you pretty much everything you need to know about any work you need to do to your rover...
________
Washington medical marijuana
Old Nov 12, 2008 | 08:43 PM
pit_ownr's Avatar
I have a 95 and it is pretty easy to replace. so to answer your question they do have one
thehun
Mar 10, 2011 08:11 AM
N.Franklin
Nov 13, 2007 08:06 PM
Fonzie
Nov 1, 2007 08:55 PM
RedElephant
Jun 3, 2007 07:31 AM
anonimaus
Oct 29, 2005 06:22 PM
