steering pulling to the right
Old Feb 4, 2013 | 07:10 PM
30more's Avatar
Default steering pulling to the right
just got done doing a differential job on my truck when I was doing the front, I noticed my ball joints were bad on my drag link. now it's pulling real hard to the right should I look at anything else other than the drag links my steering stabilizer is new
Old Feb 4, 2013 | 10:46 PM
909wheeler's Avatar
Get an alignment check done. At my shop they're free. If you end up needing one, you pay for that ($65 for a thrust angle alignment on our trucks).
Old Feb 5, 2013 | 12:09 AM
binvanna's Avatar
Thrust angle? Exactly what do you do for that? spacers on the radius arms?
Old Feb 5, 2013 | 07:40 AM
909wheeler's Avatar
Its the alignment type (vs 4 wheel or front end) On our trucks you basically set toe and let it go since both axles are solid. If thrust angle is off, it's usually an axle alignment issue or a tweaked frame.
Old Feb 5, 2013 | 08:26 AM
30more's Avatar
I didn't do anything for thrust angle because I have no clue what you're talking about can you explain a little more in detail
thanks
Old Feb 5, 2013 | 12:55 PM
RoverMasterTech's Avatar
Thrust angle is for a crooked solid axle, either front or rear.
Old Feb 5, 2013 | 01:18 PM
BrandonS's Avatar
Old Feb 6, 2013 | 12:02 AM
30more's Avatar
so alignment will fix this?
Dirtnap
May 8, 2013 02:06 PM
Doug Antsen
Mar 27, 2013 04:09 PM
DISCO1995
Oct 2, 2011 10:22 AM
llPANCHOll
Mar 1, 2009 09:34 AM
offroadlr3
Sep 19, 2008 01:49 PM
