Steering shaft coupling worn? (Video)
I’ve been chasing down the 45-50 mph wobble for a while.
Swapped the easy bits like this kit from L8… https://lucky8llc.com/collections/di...od-end-bar-set
Just tightened the little screw on the steering box following the rave instructions. I got about 1/2 turn on the screw, backed it off ever so slightly.
While in there, I noticed my steering shaft has up and down play. Rotationally its rock solid. The steering wheel is now connected mm perfect to the pitman arm movement.
Have a look at the video. Its hard to see how that coupling is fixed together. But it looks to me like there are actually some loose bolts!!?
Has anyone fiddled with this before? Does my up and down movement have cause for concern? Perhaps there is supposed to be a bit of play?
Thanks.
Thanks.
I don't know about the steering column being linked to a 50 MPH Vibration, but yours is sure worn. The new parts are pretty affordable (#12 in the diagram).
https://www.jgs4x4.co.uk/discovery-2...nt-repair-kit/
Thanks for the reply. I’ve looked at the part you’ve linked to, and it doesn’t seem to match where I have my ‘play’.
in the video, my play is around this area….
The part you link to looks different.
am I missing something? I’m happy to take a punt on the cheap replacement U joint. Although it looks like an awkward one to access..
video looks like abnormal amount of 'play' at the steering box input shaft AND the steering shaft safety coupler, AND possibly of the main steering shaft (the part the steering wheel connects to)
You need to remove the safety coupler/ U joint and test the steering box input shaft AND the main steering shaft for 'play'
If you do replace the safety coupler/U joint, be aware that there are some cheap/ wrong versions out there: one vendor sells the wrong size part. And with another version, the clamp bolts will strip very easily and should be replaced with through bolts and locking nuts!
I had a new steering shaft completely disconnect from the firewall side splines early this summer in a parking lot. This was 10 minutes after being on the highway! Ordered another under warranty. Upon install it just slid on with no resistance. Returned that one as well. Bought an excellent condition used one. It was OEM. It had to be tapped on the spines with a rubber mallet before even tightening the retaining bolt. That's how it should be. If you ever replace a steering shaft and you don't have to tap it on, don't use it. If it slides on very easily, it is a cheap version and will come loose. You do not want that happening at 60mph!!!
I want to return to look at the steering box adjustment, as I’ve only played with that once.
Following that, I have noticed a very small amount of play on the lower ball joints, so possibly suspect that as the real (and harder to fix) culprit.
My steering joint replacement was from Atlantic British.
https://www.roverparts.com/steering/...mns/QME500060/
Not cheap. But seemed to be a very good part.
Is there a consensus on ball joints causing this wobble? I have the same problem but at this point I've only had the tires balanced as a potential fix, which wasn't. I put the truck on the lift and tried to rock each tire side to side and while there was a little slop, it transferred all the way back to the pitman arm so it doesn't appear to be rod ends. There is a pretty good leak at either the box or the pump in this particular truck, the reservoir doesn't seem to be losing a whole lot of fluid but it's definitely wet below them. I need to put a different truck on the lift to compare the slop but I'm wondering if that's the easiest way to tell your ball joints are bad. There's no wander and if you don't take the truck on the highway you'd never know, but right about 50-55mph there's a definite shaking/wobble in the steering wheel.
I found my lower joints had play when I rocked them from top to bottom. Ie truck raised, one hand top of wheel, one hand bottom.
It certainly wasn't much, but I was able to see the actual joint moving when I peered around the wheel doing that.
Its also not enough play to make me worried and jump to fixing it. I’m waiting to see if something else develops as a potential cause, before committing into that job.
It’s certainly irritating.
Mine is at about 48mph.
