Steering shaft U Joint
Old 10-07-2019, 05:52 PM
Dave03S's Avatar
Default Steering shaft U Joint
Just started to hear a light click when turning the steering wheel, one click only when turning in either direction, more clicks when on bumpy road with steering wheel being turned lightly by bumps. Jacked it up and turned the steering wheel while inspecting and isolated the noise to the U-Joint closest to the firewall on the steering shaft. Not much info on here about servicing that U Joint... Any info on that? How long do I have and what should I expect in trying to service? I see where a "standard" steering shaft U-Joint is available on line and not very expensive. Doesn't look to be anything special. What does the brain trust know about this?
Thanks!
Old 10-08-2019, 03:30 AM
JUKE179r's Avatar
I’ve had this on my list to do.
I’ve read some forums to get a grease gun needle tip and squirt some grease into the rubber seal of the UJ.
Old 10-08-2019, 09:10 AM
Rovingwild's Avatar
Location: Maryland is homebase but we troam the globe in search of great views, good food, and new friends
I have recently noticed a loud clunk when turning left. I just replaced Track rod, Steering Rod and Steering damper. Ball Joints where done 6 months ago, so I was going to look ta bushings or steering box/shaft. Will look at the U joint after reading this!
Old 10-09-2019, 06:37 AM
SundayFunday's Avatar
Hey Dave,
in my experience, that knuckle in the steering shaft dries out and binds. The little ujoints fail in similar fashion as front driveshaft - close to manifold;heat and no serviceable zerks. A spray of pb blaster or lube can help for a period of time, but I wound up replacing entirely. It’s a shaft & knuckle unit.
When the time comes, I used a sawzall - just cut a relief cut - unbolted the sides and it comes right out
Dave03S (10-09-2019)
Old 10-09-2019, 09:55 AM
botbotbot's Avatar
I had a similar problem you are describing so I took the whole intermediate shaft out and checked it out. Turns out one of the u joint side had sheared and wasn't even connected. No wonder my steering was sloppy. Replaced it with a RoverLand one and no issues since. Pretty easy in and out.
Old 11-04-2019, 03:54 PM
Dave03S's Avatar
I see by using the search tool that there are two versions of the shaft... Part number QME500030 and QME500060 with the change being in mid 04.
I also see most of the intermediate shafts online are the QME500060 unit.
One thread suggested that there is a 90 degree difference in the way the QME500060 mounts from the way the QME500030 bolts in.
Does anyone know if this is a negligible difference and the ...60 is now the way to go? Or is it just the only one available now? Is there an advantage to one or the other or not much difference and the offset doesn't matter?
Thanks!
Old 11-04-2019, 05:10 PM
Sixpack577's Avatar
I bought a remanufactured steering shaft for $99.
The old shaft's u-joint was sloppy, and caused over an inch of play in the steering wheel in either direction.
They are easy to replace.
I also replaced the ps pump, and ps box.
Steers like brand new now, zero slack in the steering.
Old 11-04-2019, 05:24 PM
Dave03S's Avatar
Lucky 8 has the 500060 for $148 new. They don't list the 500030, which is why I was wondering if it is indeed not a direct swap.
Old 11-04-2019, 06:08 PM
Sixpack577's Avatar
What I find is that
500030 is for the D1
500060 is for the D2
Old 11-04-2019, 06:30 PM
Dave03S's Avatar
OK, Glad I ask, that wasn't mentioned in the thread that died without an ending in 2008.
Quick Reply: Steering shaft U Joint
