steering and steering wheel judders
Old Jan 1, 2008 | 12:31 PM
The Image's Avatar
Default steering and steering wheel judders
Sometimes when I go over a bump, my steering and steering wheel judders quite disturbingly. Any ideas? It's been happening occasionally for a while but I've just lived with it but yesterday it did it so bad I had to pull over to the hard shoulder where it decreased and stopped.
Old Jan 1, 2008 | 01:54 PM
raid13's Avatar
Default RE: steering and steering wheel judders
leaking or empty steering shock or bad end bushings
worn pan hard bushings or loose nuts
and not normaly but radius arm bushings can cause this
Old Jan 1, 2008 | 03:18 PM
geotrash's Avatar
Most common cause is a weak steering stabilizer. Old Man Emu makes a replacement that is well regarded by folks here.
Dave
Old Jan 1, 2008 | 03:41 PM
Sounds like most of the bases are covered, let us know what you find.
Old Jan 5, 2008 | 06:22 AM
The Image's Avatar
When I bought the landrover, a few people pointed out that something was leaking on the axle and that it needs new seals but I forgot about it. Could that be the problem? What is it? All I recall was it was a bulge bit of the axle!
Old Jan 5, 2008 | 09:28 AM
On a 94, yes, your swivel joints most likely need to be serviced, bearings repacked, seals replaced and make sure the proper preload is set.
Old Jan 5, 2008 | 05:43 PM
The Image's Avatar
Thanks. I'll do that.
Vinndego
Jan 6, 2014 11:14 AM
dcarr1971
Feb 8, 2013 08:16 AM
nick731
Nov 16, 2010 12:25 PM
Marku60
Defender
Sep 9, 2008 02:48 PM
BENROVERN
Nov 5, 2007 09:19 AM
