Steering wheel removal
Old Jul 11, 2017 | 03:19 PM
LR03NJ's Avatar
Default Steering wheel removal
Need help / advice how to remove steering wheel. Also tools if you remember. Thanks
Old Jul 11, 2017 | 03:37 PM
Luckyjayb's Avatar
you gonna re wrap it? That's one of my
next projects
Old Jul 11, 2017 | 03:44 PM
mln01's Avatar
Instructions are in the RAVE.
Old Jul 11, 2017 | 03:47 PM
OverRover's Avatar
Its been a minute since I've had to remove a steering wheel. It's the rotary coupler that can be a PITA. I'm little help, but here are the RAVE instructions.
Old Jul 11, 2017 | 03:55 PM
OverRover's Avatar
You might find this useful, @ 6:47 you can see the rotary coupler. Tape that in a fixed position ( you can see the OE tape ).
Old Jul 11, 2017 | 04:08 PM
LR03NJ's Avatar
next projects
Jason, I have seen those, but seems a bit time consuming to do. Very nice color combination thou. I got a good one from ebay, just arrived. Still have dimples intact.
Thanks
Old Jul 11, 2017 | 04:12 PM
LR03NJ's Avatar
How do you do this? Do you have the RAVE with you all the time? I am really amazed. Man! I envy you! LOL!
Thanks so much, I just have to locate the THANK button on me phone. OOOPS, there is none. Later then.
Old Jul 11, 2017 | 04:16 PM
CarParter's Avatar
I had a total nightmare come true removing a steering wheel from an '03 D2. After removing the alignment bolt, the steering wheel wasn't coming off. I was hitting it from 3 and 9 for no use. I even used quite a lot of WD-40 - didn't help either.
Old Jul 11, 2017 | 04:31 PM
LR03NJ's Avatar
Ill get there in an hour, I'll report.
Old Jul 11, 2017 | 05:29 PM
LR03NJ's Avatar
Thanks guys, I replaced the steering wheel already. I had to run HomeDepot get that freekin torx wrench. Thanks for the diagram.
