Steps for Driveshaft install
I'm going to put my Tom Woods in this week, and want to make sure I have the right steps for the install...I haven't done much work on my trucks but that's about to change.
Does this sound right?
1. Chock rear wheels
2. Put front axle on jack stands so that front wheels will spin
3. Put tranny in neutral (and CDL unlocked)
4. Unbolt current driveshaft, careful to not round bolts/nuts (socket on the bolt and channel locks on the nut)
5. Bolt in new driveshaft using same hardware. Use lock-tite.
6. Put a squirt of grease into each of the nipples
For #5: do you guys use torque wrenches? Or do you just crank?
For #6: What kind of grease should I use? And how do you get the grease into the nipple (what kind of grease can)?
I'll be sure to take some pics.
Thanks, Dustin
Thanks, Dustin
Just use any good grease, I use Green Stuff, it is for farm equipment and is very water and dust repelant.
You will need a grease gun and a tube of grease.
Make sure that you have a flexable hose for the grease gun.
Grease the u-joints at EVERY oil change and they will last this side of forever.
http://www.napaonline.com/MasterPage...ion=Grease+Gun
http://www.napaonline.com/MasterPage...+Multi-Purpose
http://www.napaonline.com/MasterPage...+Hose+Whip+End
You can grease them with the stiff hose but it is easier with the flexable one because if the nipples are not in the right spot you can reach over and around the u-joint to reach them.
1. Chock rear wheels YEs
2. Put front axle on jack stands so that front wheels will spin Only need one wheel off the ground
3. Put tranny in neutral (and CDL unlocked) Yes
4. Unbolt current driveshaft, careful to not round bolts/nuts (socket on the bolt and channel locks on the nut) No, never use channel locks on nuts or bolts if you want to keep them. One open end and one box end on the diff input flange. Just a box end on the FWD output flange as the they are captive bolts
5. Bolt in new driveshaft using same hardware. Use lock-tite. Better to use new self locking nuts, but if you reuse the old, split washers will do. I never use loc-tite on drive shaft nuts.
6. Put a squirt of grease into each of the nipples No. You want to see new grease come out from around all 4 seals on each u-joint. That's the correct way to lubricate a u-joint.
For #5: do you guys use torque wrenches? Or do you just crank? I don't use a torque wrench on drive shaft nuts. But I'm able to get it pretty close without.
For #6: What kind of grease should I use? And how do you get the grease into the nipple (what kind of grease can)? A good grease for harsh environments. I use Castrol Pyroplex Blue
Thanks antichrist, great feedback.
Does anyone know where I can order new self-locking nuts for the re-install?
Also, simple question: where would you place the jack and jackstand to get one wheel off the ground?
I've rebuilt the steps:
1. Chock rear wheels.
2. Jack at least one front wheel off the ground.
3. Put tranny in neutral (and CDL unlocked).
4. Unbolt current driveshaft, careful to not round bolts/nuts (On the diff input flange: one open end and one box end wrench. On the FWD output flange: Just a box end wrench as it has captive bolts)
5. Bolt in new driveshaft using new self-locking nuts, if possible. Otherwise, just use same hardware.
6. Squirt high quality, synthetic grease into each of the nipples until new grease comes out of all 4 seals on each U-joint.
