stereo volume only works with steering wheel
The cause is dirt inside. You can clean the internals of the volume dial. I did that and it worked for a while, so it's not a permanent solution. You have to pull the head unit, open it, remove the front cover and then you can pry open the potentiometer by bending the tiny metal tabs gently. Clean the internals with a swab and alcohol.
The sustainable solution would be replacing the potentiometer. Unfortunately I haven't found it from a parts store yet.
Broken08
Audio/Visual Electronics
04-12-2015 07:21 PM
