stereo volume only works with steering wheel
Old Oct 19, 2023 | 07:23 PM
keninnc's Avatar
Default stereo volume only works with steering wheel
If the stereo volume only works with the steering wheel is this more likely an issue with the stereo or amplifier?
Old Oct 20, 2023 | 08:24 AM
mollusc's Avatar
Has been a known issue with the volume ****. It's the head unit, not the amp. I don't remember if there's a fix or not.
Old Oct 20, 2023 | 09:12 AM
Discorama's Avatar
The cause is dirt inside. You can clean the internals of the volume dial. I did that and it worked for a while, so it's not a permanent solution. You have to pull the head unit, open it, remove the front cover and then you can pry open the potentiometer by bending the tiny metal tabs gently. Clean the internals with a swab and alcohol.
The sustainable solution would be replacing the potentiometer. Unfortunately I haven't found it from a parts store yet.
Old Oct 20, 2023 | 11:29 AM
whowa004's Avatar
When mine did that it signaled that the head unit was on it's way out..
eitydeuce
Mar 10, 2020 05:08 AM
No Doubt
Jul 18, 2019 04:44 AM
eitydeuce
Apr 6, 2018 05:23 PM
Broken08
Audio/Visual Electronics
Apr 12, 2015 07:21 PM
mdf27
Jan 31, 2012 05:41 PM
