Sticky on how to replace tranny fluid
Old May 20, 2020 | 07:44 PM
redwhitekat's Avatar
Default Sticky on how to replace tranny fluid
Can we have this section updated. Just so people that read it know to leave the truck running when you go to refil a second time after going though the gears
Pump the new transmission fluid into the fill/check hole until it starts to come out of the hole, replace the plug.
Start the truck and shift though all of the transmission gears and hold each one for 2-3 seconds, starting in park and continue until you reach 1st, then go back to park.
Remove the fill/check plug and make sure that the transmission is full, fluid should come out at a nice steady rate, if so you are full.
Old May 20, 2020 | 11:19 PM
escott16's Avatar
just did it this last week would have been nice to have it a sticky. I made the mistake of checking it off and fluid went everywhere
Old May 20, 2020 | 11:54 PM
Best4x4's Avatar
How To Change Transmission Fluid on a D2
Are you talking about this write up under the Write ups & How To's and Must Read sticky? It mentions starting after adding fluid and then checking it to see how much comes on in a nice steady stream. It's been a link on a sticky since 09 and the pictures are gone, but the steps are spot on.
Old May 21, 2020 | 04:12 AM
JUKE179r's Avatar
For me I kept forgetting to leave the truck running when I check the fluid level the second time after running through all the gears.
Old May 21, 2020 | 05:25 AM
ya but it doesn’t mention to leave truck running then go back and refill
Old May 21, 2020 | 06:55 AM
mollusc's Avatar
"Start the truck and shift though all of the transmission gears ... Remove the fill/check plug and make sure that the transmission is full"
Old May 21, 2020 | 07:34 AM
exactly. Just wondering if we can edit that so it says after shifting through all of the transmission gears leave truck running remove fill check plug and make sure tranny is full
maybe just me. But if someone reads that they will probably shut it off before rechecking
never mind
Old May 21, 2020 | 08:13 AM
NewToTheTwo's Avatar
Theres always this too - Maybe as a visual reference, this vid could be added to that thread...
Old May 21, 2020 | 08:18 AM
mollusc's Avatar
never mind
It doesn't say to shut off the truck. Goes directly from "start the truck" through various steps through to "make sure it's full."
True, additional confirmation that you leave the truck running might help, but the directions are accurate as they are.
Old May 21, 2020 | 08:39 AM
never mind
I have to agree - For someone thats never done this service, the verbiage is not obvious....
Its a simple add to the instructions to completely eliminate possible confusion.
