still can't figure this out need some help!
Old May 10, 2011 | 12:09 PM
sloan74's Avatar
You might of blown a head gasket when it overheated.
What did the oil look like when your drained it? What does it look like now?
Call Mike for sure.
Old May 10, 2011 | 12:22 PM
DiscoRover007's Avatar
Sounds like your truck did a lot of the same things when I had a blown head gasket. Make sure you check everywhere for the leak. We didn't suspect a hg on mine for the longest time because it wasn't really observable and I didn't get any puddles.
Old May 11, 2011 | 07:24 AM
rover newb's Avatar
Call Mike for sure.
the oil looked very dirty and broke down when i changed it. right now it looks fine. mike did get a hold of me and gave me some great advice and a few steps to take. so i'll do that stuff and go from there.
Old May 11, 2011 | 12:44 PM
yloDiscoII's Avatar
Make sure to post up a follow up with what you find/what you fix, for future readers, good luck with your fix.
Old May 11, 2011 | 02:28 PM
drbshort's Avatar
3rd Gear
Default Need help too
I have the same problem, overheating. I have replaced both head gastkets, radiator, and thermostat. Ran fine for about 4 weeks, and suddenly, overheated and all the coolant came out of the overflow. Refilled it, bleeder open, and overheated again within minutes. My mechanic checked the water pump and everything he could think of, (and he replaced the head gaskets so knows what he did), and can't figure it out. Any ideas? Should I take it to the dealer?
Old May 11, 2011 | 02:44 PM
Was it a rover mechanic? Maybe he didn't torque the heads right...
When it over heats is it consistent? Or does it rise and then fall? Maybe you have air in the system.
Old May 12, 2011 | 03:00 PM
drbshort's Avatar
3rd Gear
Default Overheating
He is not a Rover mechanic. Works for Lexus and now Honda. I drove it the other day and the it did overheat, and then the temp came back down to normal, but then went back to hot. When he drove it, it just went hot and when I drove it back from him it just stayed hot. It seems to me there is air in the system, but how do you get it out? Or how do you fill it properly in the first place?
Thanks for your help.
Old May 12, 2011 | 03:17 PM
yloDiscoII's Avatar
Originally Posted by drbshort
.....I drove it the other day and the it did overheat, and then the temp came back down to normal, but then went back to hot. When he drove it, it just went hot and when I drove it back from him it just stayed hot. It seems to me there is air in the system, but how do you get it out? Or how do you fill it properly in the first place?
Please tell us that you are NOT driving it around with the needle in the RED
Here's a thread on bleeding the system --> https://landroverforums.com/forum/di...tem-dii-23072/
Old May 12, 2011 | 05:07 PM
drbshort's Avatar
3rd Gear
Thanks, I will go try this and see. I always have that gurgling or swishing sound inside the dash, even after refilling it. Maybe I've been doing it wrong so I will let you know.
Old May 12, 2011 | 05:15 PM
yloDiscoII's Avatar
One tip is NOT to open the coolant reservoir cap with the engine warm...it will suck in air. Did this the other day thinking it was cool enough
