still lost on this discovery engine issue
Old 03-21-2017 | 09:35 AM
escott16's Avatar
Default still lost on this discovery engine issue
alright guys i know this topic has been beat to death, my 03 disco has engine knock, 2003 4.6 51000 miles. ive already switched to rotella 15w-40, the knocking is present when hot and goes along with rpm but drowns out with noise at higher rpm, i did a oil pressure test and got 22psi idle 50psi at 2k (which i believe is in spec) i used a stethoscope and i think its around cylinder 7
(closest to driver seat i think) its been knocking for 10k miles can anyone help should i just deal with it? i do not plan on putting thousands into this chasing it around considering i got lucky and paid 2k for it in mint condition
Old 03-21-2017 | 10:08 AM
Red5's Avatar
With those pressures, and if it's quiet on startup and starts tapping as it warms up, probably a slipped liner.
If you are not loosing coolant, it may not be a death sentence. Others have run many miles with the tapping, or there are drill, tap, plug fixes that others have done.
https://www.google.com/search?q=land...utf-8&oe=utf-8
Old 03-21-2017 | 12:23 PM
Dave03S's Avatar
I've read just as many posts of people who thought they had a slipped liner and found the noise to be valve train related.
Were it me I'd run a few courses of seafoam or similar through the oil to see if some gunk can be removed. Switching to Rotella is a good start but even Rotella will take some time to clean it out good. It could take a few thousand miles of Rotella to get a start on cleaning out the gunk. How black does the oil look? With the Seafoam in oil I'd run a few hundred miles and check. If you have the skills pop the valve covers and see what it looks like.
I always like to try the easy stuff first rather than worry about the worst case scenario.
Old 03-21-2017 | 03:53 PM
escott16's Avatar
you said seafoam in the oil? ive seen people put it in the intake and in the gas but not the oil. and i just changed my rotella out for new rotella same weight and the oil did seem alittle dark
Old 03-21-2017 | 04:18 PM
KingKoopa's Avatar
Seafoam is just a detergent, there are several on the market that will have the same effect. Breaks up sludge
Old 03-21-2017 | 04:27 PM
LR03NJ's Avatar
Yes, seafoam with gas or oil. But anyway, will you be able to shoot a short video with sound? That seems to work better understanding your noise/tick situation.
Old 03-21-2017 | 04:28 PM
escott16's Avatar
also one thing when i first switched to rotella the noise mostly went away for about a month then slowly came back . what would you suggest for a oil additive to quiet the valvetrain
Old 03-21-2017 | 04:29 PM
escott16's Avatar
im at work on my break ill run up and get it to knock
Old 03-21-2017 | 05:42 PM
escott16's Avatar
Old 03-21-2017 | 06:25 PM
huggi's Avatar
I had a similar tap (tho sounds like half the beats) I noticed started at 194 degrees. I did the inline thermo mod, kept my temps under 194 and my noise is gone.
