Strange bang
Old Sep 18, 2020 | 08:43 PM
Wheelspin's Avatar
Default Strange bang
Was out in the city heading for the country and as I accelerated hard, I thought I heard and felt a bang in the rear.
i stoped and took off again and felt heard it, it’s a decent bang, I first stopped and checked tyres they are all ok, I’m not sure how you check a driveshaft but I crawled under grabbed each end and pushed up and down then side to side, I felt no play .
im guessing diff ?
or could it be auto trans ?
Old Sep 18, 2020 | 09:33 PM
I Brake For Cats's Avatar
Do you feel any new vibrations at any speeds? I recently broke my engine and transmission mounts abruptly and it was pretty noticeable bang. While it felt further back to me, the bang itself came from the passenger side engine mount.
Good luck, these are worth checking closely with a flashlight in any case.
Old Sep 18, 2020 | 10:03 PM
Wheelspin's Avatar
Thanks once it’s dark I’ll go look
Old Sep 19, 2020 | 12:44 PM
frostythor's Avatar
check your drop links, if they break they will just go back together you cant see the ball joint is separated until you jack up the car on one side, I only saw mine as I removed the shocker and had to lower the axle to replace the lower bolt on the shocker
Old Sep 20, 2020 | 03:53 AM
Wheelspin's Avatar
Might have to take it into a shop, the bang has stopped , when I hit 40-50k on some roads the truck body swings from side to side, faster and slower it’s fine , one weird sensation
Old Sep 20, 2020 | 09:35 AM
I think frostythor was onto something with the drag link. When I bent mine it had me jerking across my lane on the highway randomly like I was drunk. Ruts on the road make it much worse. You can definitely do the repair yourself if you do your research!
Try to take it in for an alignment, usually if it's bad they won't do it. If it is a drag link or any other part in that region, get an alignment after your change it out.
RoverLife_
Feb 18, 2018 12:04 PM
Wranglol
Apr 15, 2017 11:26 AM
batard
Jun 5, 2016 07:01 AM
Zelatore
Feb 13, 2016 09:21 PM
abran
Sep 8, 2014 11:20 AM
