Strange clicking noise
I'm hoping someone can help me identify this strange noise. It is coming from the passenger side of the engine toward the back. It's the background clicking noise that your can hear in the video. Because it is inconsistent, I don't think it is coming from the rod bearings, valves, etc. I do have a misfire in cylinder 3 but I think that is from a bad coil pack. I'm going to change that next. The engine also does not run rough like you would expect if it was from a consistent misfire.
The following 2 users liked this post by BroncoCanuck:
Richard Gallant (12-20-2021),
The Deputy (12-19-2021)
That's a steal for $500 if it isn't rusted to hell.
Can't see your video, but a fast paced clicking can be the SAI solenoid, located on the side of intake manifold drivers side toward the back.
If it is SAI related, don't let it scare you. SAI system parts are relatively cheap these days and easy to swap. I just revamped my entire system for like $150 recently. Pump, valves, solenoid, and replaced metal piping with rubber hose behind the intake manifold.
KernowDiscovery
05-30-2014 10:44 PM
