strange grinding noise when starting
96 Disco 1 manual-trans...
my truck usually starts up right away, but once in a while when i turn the key i will just hear a very loud and steady grinding noise. sounds nothing like a car turning over, more like a power saw. seems to happen more often when i've been through mud/water, but not sure about that.
is the starter not fully engaging every time?
on
RE: strange grinding noise when starting
ORIGINAL: roverboy
Most likely the flywheel is missing some teeth change it before you ruin your starter everytime you get to that damaged spot on the flywheel the starter is not engaging causing it to make that grinding noise.
HEY,
JUST HAD THE SAME PROBLEM HAPPEN TO ME, IT'S NOT YOUR STARTER. IT'S YOUR FLYWHEEL. EVERYBODY I TALKED TO SAID IT WAS MY STARTER. IF YOU WANT TO CHECK IT TAKE OFF YOUR STARTER AND ROTATE THE TEETH ON YOUR F-WHEEL. IF ITS CHIPPED AND WORN YOU NEED A NEW ONE. I PAID $60.00 FOR THE WHEEL AT ROVERLAND PARTS ONLINE AND $350.00 TO GET IT REPLACED. HOPE THIS HELPS.
MY STARTER WENT BAD TWO YEARS AGO, I REPLACED IT WITH A BOSCH. IT TOOK TWO YEARS FOR THE FLY WHEEL TO SHOW ANY PROBLEMS. MY STARTER IS STILL IN PERFECT CONDITION SO....... DO CHANGE BOTH BUT CHECK THE FLYWHEEL FIRST AND ALSO CHECK YOUR STARTER. GO ONLINE FOR YOUR STARTER MINE BROKE DOWN IN VA. I GOT RIPPED ALONG THE INTERSTATE BUT YOU CAN FIND THEM ON EBAY FOR AROUND $100. HOPE IT WORKS OUT FOR YOU BUT DO SOME EXAMINATION AND YOU WILL BE GOOD TO GO.
