Stuck Windows...
Old Apr 8, 2014 | 07:21 PM
Rocko99's Avatar
Default Stuck Windows...
Driver window won't go up or down unless I hold it level. Seems to be binding on the edge of of the door frame. Any ideas on how to fix it? Is this common?
Thanks in advance.
Old Apr 8, 2014 | 07:26 PM
ZGPhoto's Avatar
very common.
Old Apr 8, 2014 | 07:28 PM
Rocko99's Avatar
I assume I need a new 'regulator' and can not simply tighten up the bracket holding the glass?
Old Apr 8, 2014 | 07:34 PM
ZGPhoto's Avatar
Not really, in reality you probably have broken rollers on the regulator
Old Apr 8, 2014 | 07:40 PM
Rocko99's Avatar
Thanks. Do you know the best place to get a replacement? Does the brand matter?
Old Apr 8, 2014 | 07:47 PM
ZGPhoto's Avatar
You could buy it from the company I work for - REGULATOR LH FRT WINDOW '95 RANGE ROVER CLASSIC, DISCOVERY I, DISCOVERY II, PLH541, LR006374 - Rovers North - Classic Land Rover Parts
Or one the fine other Rover companies like Lucky8.
Old Apr 9, 2014 | 07:25 AM
Lowest Bidder's Avatar
If you have access to a 3D printer you can print the wheels in two parts using ABS filament and glue them on the existing shaft with acetone. real easy and it costs about 2 cents in ABS. Lot more durable than the original rollers too because ABS won't dry out. I can PM you the file if you want.
Old Apr 9, 2014 | 08:10 AM
ZGPhoto's Avatar
Haha damn technology is cool. Do that many people really have access to a 3D printer? I want one..
Old Apr 9, 2014 | 08:32 AM
Yeah! They are catching on really fast, I bought mine last fall for 800$ and I repair tons of stuff with it. As long as you can draw a 3D model of it, you can print it. Here's a little bracket I made after the ears of the inertia sensor broke off on a gravel road...
Here's the roller I printed to replace the broken ones on the passenger side window.
Old Apr 9, 2014 | 08:34 AM
ZGPhoto's Avatar
That is awesome!
