stuttering and hesitation
I had some hesitation and stuttering when driving on high way and taking my foot of the gas. The problem went away and the car was driving just fine both on highway and in the city. Today the car started stuttering again when on the highway, but than it continued doing so to a lesser degree even when I was on the surface street and some stuttering even when I was driving, meaning my foot on the gas.
I recently wanted to change the plugs, but when I pulled them they were in good shape and they must have been replaced at some point since what is in there are Autolite double platinum and not the factory champions.
I do not have any codes and did the seafoam induction a couple of times before.
I have an ultra-gauge and have it set up to show oxygen sensor readouts on the first page, but don’t know what to do with the numbers.
Any advice suggestion to find the cause of the problem will be appreciated.
Could this be due to plugs and wires, even if there are no codes?
BTW, it was driving smooth today, but cominig to work I don't take high way, it is mostly 50mile/h streets. I did clean my MAF previously, but at that time I had MAF codes too, which were likely due to a loose MAF sensor plug.
As far as the Sparkplugs and wires are concerned, I have autolite double platinum and i think my wires are still factory. I do have Bosch IR and 8mm silicone wires ready to be installed, but without any misfire codes, I am not sure if this will fix the problem.
I have heard about the Crank Position Sensor problems, but does it cause problems mostly at highway speed idle and the same for fuel pressure. I have to look into Rave's to see how to check the IACV.
My IACV was toast and made vehicle idle at 2000, so if left in gear it would approach 50 +. Cleaning helps. CKP sensor can have failures with no codes, most other sensors can't. Fuel pressure is costly to deal with on D2 as fuel filter is integral with pump in the tank, not a cheap fix or even an easy to get to test. Plugs and wires good idea, but it seems that lots of them also bring the misfire codes. IACV cheap to remove and clean with carb cleaner, avoid moving the tip, it is a 180 - 200 position stepper motor.
I wanted to change the wires, but it is not an easy task, some of the SAI hoses that needs to be taken off have clamps on in a way that I cannot even get to the screw to loosen it. I have no idea how they were put on.
Plugs and wires are next to be changed but as you know it is not the easiest thing to do and I have afew of those hoses upside down, where I can't even get to the clamp screw.
