Subwoofer
Old Apr 10, 2014 | 09:28 PM
  #31
ralphobell's Avatar
Page 128
Old Apr 10, 2014 | 09:29 PM
  #32
ninjaff21's Avatar
wow i was on 185 looking at the ICE section
for me 128 is windscreen washers
Oops i downloaded the wrong manual
Old Apr 10, 2014 | 09:32 PM
  #33
ralphobell's Avatar
Sorry also look at page 126 or 127...which ever matches your unit. The wires do change colors.
Old Apr 10, 2014 | 09:33 PM
  #34
ralphobell's Avatar
This is the manual you want:
http://www.d2owner.com/Manuals/Disco...20Diagrams.pdf
Old Apr 10, 2014 | 09:35 PM
  #35
ralphobell's Avatar
Crap sorry man that is for the 03 and 04.
Old Apr 10, 2014 | 09:37 PM
  #36
ninjaff21's Avatar
My system has 2 A post 2 speakers on each front door 2 speakers on each rear door and 2 subs on the tail door along with the headphone inputs behind the middle row of seats. do i have the system on 126 and 127 if so in the back of the truck are those wires for the subs going to be the same color and will they be high range or low range? since that would be post amp i would assume they are low range and i would need my RCA converter instead of my high line plug that comes with the sub. i don't have harmon i know that and i pulled the stock subs and they don't have an amp on them.
Old Apr 10, 2014 | 09:38 PM
  #37
ralphobell's Avatar
Here is for the 99 to 02 model
http://www.d2owner.com/Manuals/Disco...%20Ciruits.pdf
Under the audio section
Old Apr 10, 2014 | 09:41 PM
  #38
04duxlr's Avatar
Oh man, this is getting crazy. Look at the wiring diagram in the Crutchfield link I posted. The wiring for the amplifier is what you need to be using to guide you. That shows the plug that connects to the amp. It has both input and output wiring. You want to look for the following: Back Door Sub 1 + BN/BK, Back Door Sub 1 - WT/BK; Back Door Sub 2 + PK/BK, Back Door Sub 2 - RD. There are 2 subs in the rear door, and those are the colors for the wiring pairs for each sub. The colors will be the same in the rear of the vehicle.
If it were me, I'd cut the wires and connect them to the high level input for your new sub and leave the wires to the factory subs disconnected. If you want to get fancy you can rig up a plug for the speaker wiring so you can reconnect the factory subs if you ever need to pull out the aftermarket sub for extra room. And yes, you need to use the high-level inputs on the aftermarket sub. If you don't, then you will need to run a remote wire to trigger the amp as the line-level inputs (RCA) won't have enough voltage for the amp to sense when it should kick on.
Old Apr 10, 2014 | 09:44 PM
  #39
ninjaff21's Avatar
Ok so looking at the crutch field diagram the colors it is saying that is connected into the amp when i open my trailer wire area will be the same color? and i cut those and solder in the subs wiring kit.
Old Apr 10, 2014 | 09:50 PM
  #40
ninjaff21's Avatar
is the color on the crutch field the same as what ralph posted? i mean that in the way of the key
Back Door Sub 1 + 1 BN/BK
Back Door Sub 1 - 2 WT/BK
While on the land rover diagram those rant connected to the same speaker?
