Subwoofer buzz when raining
Old Jul 22, 2012 | 08:50 PM
Kevintj1's Avatar
5th Gear
Default Subwoofer buzz when raining
Whenever it rains, I get an annoying buzz from my subwoofer in the back door. It only lasts a few minutes then it goes away, so I can live with it if I have to. I assume it is some kind of short or grounding issue, but I have no Idea where to start. Any ideas?
Old Jul 23, 2012 | 06:09 AM
wilson96rr's Avatar
Are you sure it isn't a vibration? Mine was making a buzzing sound and it turned out to be the license plate vibrating. A little silicone fixed it. The rain thing kind of has me puzzled though. Also, the speakers in the subwoofer tend to fall apart over time. When we remove them, it is rare to find one that has good speakers. Hope that helps you out.
Old Jul 23, 2012 | 10:57 AM
Kevintj1's Avatar
5th Gear
I appreciate the thoughts, but it is definitely tied to the radio. It immediately stops when I turn off the radio. However, the volume doesn't change at all even when I turn the volume all the way down. So, I know it isn't just a blown woofer since it isn't based on the volume of the radio. It also only happens when it rains, which also confuses me.
Old Jul 23, 2012 | 02:36 PM
grandkodiak's Avatar
Next nice day, take a hose and spray different parts of the car good enough for flowing water to go into the body work like it would in the rain. start at different spots until the buzzing starts. Sounds like water causing an issue somewhere... why it goes away, no idea lol. Is the weather seal around the rear hatch still good? And dry rott or cracking? My first place to look guess would be the rubber seal where the rear window wiper cable runs into the door behind the spare tire carrier. It might be cracked, or missing completely, then water can flow into the door. Try replacing that seal, or coating it with rtv... or some good ol duct tape haha.
ps. it doesnt have to be tied to the radio necessarily, if any electrical component is arcing it can induce a signal through neighboring wires or the antenna itself... put on a good AM radio station and put your wipers on in almost any car, and youll pick up a buzz/hiss that go along with the wiper motors turnign on and off
Twins Disco
Dec 18, 2016 07:50 PM
Externet
Nov 26, 2013 06:43 PM
Christina Jon Harrington
May 27, 2012 06:51 PM
Gerard
Mar 24, 2011 07:35 AM
Bad News
Aug 27, 2010 06:05 AM
