Suggestions please
Old Jul 30, 2019 | 08:00 PM
Rev'dup1's Avatar
3rd Gear
Default Suggestions please
I have a 2003 Discovery 2. Trouble shifting out of park. Also, engine stsrts easy and after idling for a few minutes or even after running a short time it suddenly stops running. No sputter, no earning and then won't start for several minutes. Is there a connection between safety switches and cutting out? Are ignition packs going bad?
Thank you.
Old Jul 30, 2019 | 08:53 PM
mollusc's Avatar
cutting out may well be the crank position sensor (known as the cps). there are a number of threads relating to it on this forum -- most people say that it's a pretty easy replacement except for getting to the connector plug.
Old Jul 31, 2019 | 08:31 AM
Rev'dup1's Avatar
3rd Gear
Default Thank you
Thank you. I will seek out further info now that I have a hint.
Blessings.
Old Jul 31, 2019 | 08:40 AM
JUKE179r's Avatar
Get a Bosch CPS and not a Duralast.
Old Jul 31, 2019 | 09:03 AM
CollieRover's Avatar
Trouble shifting out of park is likely the Brake Switch, get the new Autozone type per Best4x4, I went with stock and the design is a little janky. 5 minute job.
That sounds like a CPS as mentioned, and only use a Bosch for replacement or you will be doing it again in a year.
Old Jul 31, 2019 | 08:23 PM
Extinct's Avatar
Easy way to test for CPS - after it dies dump a large glass of cool water on the back on the engine on the drivers side, if it starts immediately it is a CPS. they get hot and the electronics don't work.
john47uk
Oct 3, 2014 01:32 PM
MuleyJ
Apr 9, 2012 09:41 PM
carlos84
Jan 10, 2012 10:22 PM
fishhawk
May 19, 2010 07:55 PM
nfakbc
Apr 8, 2010 03:51 PM
