Sunroof drain exit location
Old Sep 12, 2013 | 02:54 PM
Snafu / Disco Fries's Avatar
Default Sunroof drain exit location
OK folks... RAVE and search are not helping me out here. I'm looking to find out where the drains from the sunroof go to exit. I think they are clogged up, and I will sometimes see a few drips around the front splash guards long after a rain showing a slow drip. I just can't find the silly tubes or exit. I was going to clean out the AC lines, and figured take a look at those too.
Old Sep 12, 2013 | 04:52 PM
groeder24's Avatar
I believe they drain behind the taillights.
Old Sep 12, 2013 | 10:07 PM
Looking for the front drains. Looks like it goes down the a pillar, but from there I can't tell. Looks like it drains inside a frame area. Found an area with crude where it drips but not a point I could access. Passenger side drained out when I poured water in, but driver side did not.
Old Sep 12, 2013 | 10:10 PM
Here is a spot like I was talking about on drivers side. Drips out from under that area. Took pics of it but hard to tell what the pics are of.Name:  photo_zps483b4e6c.jpg
Old Sep 13, 2013 | 05:25 AM
drowssap's Avatar
I think you maybe right the A & B pillars would be the logical place to run the drains, but this is a LR.
Old Sep 13, 2013 | 10:04 AM
Each of the 4 drains drains out behind each of the 4 wheels.
Old Sep 13, 2013 | 10:41 AM
Have you actually seen an exit area? The only spot I could find at the bottom near the D/S was about 6" back from the end of the frame near the running board in back of the front wheel. A bunch of muck (like what you would see in the AC drain) in this thin slit in a box by the frame. No way to get into it though. Not sure if the pipe is redirecting into there. Very odd exit point, and it is plugged up somewhere and just dripping through slowely. Causing too much to go towards the P/S drain and hence cause some wetness over there on that side I think.
Old Sep 15, 2013 | 12:24 PM
borchera's Avatar
We went through a plug front drain and we had water on the driver's side floor. Thought it is was the windshield until I found the front drains and unplugged both of them. The driver side drain tube was filled with water.
The front drains are under the truck tucked up into the chassis (you will see them with a flash light).
2003 Discovery 137K
Old Sep 15, 2013 | 07:16 PM
2003 Discovery 137K
I'm wondering if since I have the running boards if it is tucked in a way I just can't see it.
oljohnboy
Aug 15, 2020 10:50 PM
wardpower
LR2
Jan 30, 2020 11:52 PM
Roveroh
Aug 7, 2008 09:42 AM
PITTDISCO
Jun 30, 2008 10:26 PM
skewett
Jun 3, 2007 08:15 AM
